- Main Amp
- Additional Amp
- StormAudio PA 16 MK3
- Computer Audio
- ROON Nucleus One
- Panasonic UB9000 4K UHD Player (for media discs)
- RTJ 410
- Front Wide Speakers
- JTR Neosis 110HT
- Center Channel Speaker
- MartinLogan Focus C-18
- Surround Speakers
- JTR Neosis 210RT
- Surround Back Speakers
- JTR Neosis 210RT
- Middle Height Speakers
- JTR Neosis 110HT-SL
- Front Height Speakers
- JTR Captivators - 4000ULF-TL x2 + 2400 x6
- Rear Height Speakers
- Other Speakers or Equipment
- VTI Amp Stands for the Monoblocks
- Video Display Device
- Sony 98X90L
- Remote Control
- AVA Cinema
- Streaming Equipment
- Kaleidescape | Lenova X1 - Intel NUC for Roon
- Streaming Subscriptions
- Satellite System
- Dish Joey 4K
- Other Equipment
- Zero Surge 8R15W-1 | Salamander Synergy Equipment Stand
We have a Denon receiver in our sunroom... very old, but it has served us well. It powers a pair of B&W 600 series speakers in the sunroom that we purchased back in 1994 - yep... 30 years ago. The Denon also powers a pair of Klipsch Synergy outdoor speakers that still do pretty well. Angie listens to FM radio during football season because she will not watch Bama football on TV - she always listens in the sunroom unless we are Jeep riding. FM is spotty and fuzzy, but she sometimes uses her phone to listen. We listen the majority of the other time to XM Radio via a Pioneer Airware (it's antique as well). The Aireware goes in and out because the antenna can't see the satellite very well due to limited placement options.
What we need... a receiver that has the A and B switches so we can listen to either or both pairs of speakers, Internet Radio... something we can tune in Bama football, which is about the only time we'll need it, and something that will play XM radio. Roon Ready won't hurt.
The speakers are to replace the B&W speakers that are on stands now. We can keep the stands and use bookshelf speakers or buy tower speakers. Preferably, some with less than 90dB sensitivity, unless there is a separate volume control for A&B. When both pairs are playing, we prefer the outside be a little louder than the inside, and the Klipsch Synergy SA3 speakers are spec'd at 94dB sensitivity.
These speakers are not played very loudly, so they can have low sensitivity with no issues. This is not critical listening by any means.
I want to nail down the receiver first, then I'll start looking at speakers.
We have 1 gig Internet speed and a robust network, which is wired and has Wi-Fi, so we are covered with the network.
The first receiver I came across is the Yamaha R-N600A - Amazon: http://rb.gy/6sbr5r
It uses Musicast app on a phone or tablet, which I don't think would be ideal. Having to rely on the app on a separate device to keep things connected wirelessly is unreliable, as evidenced by numerous bad reviews due to lost connections. If the receiver itself can connect to XM via a wired connection to the Internet, then we should be fine, but I don't understand Musicast well enough. Bottom line... we don't want to rely on a phone or tablet app to control the streaming or for connection to the streaming. We do not want to use Bluetooth either. I could be misunderstanding Musicast and how it works.
It uses the airable.Radio, a service of TuneIn, which has at least one Bama football station, 95.1 in Montgomery, Prattville, so we'd be covered there. It does NOT have HDMI out, so the UI will have to be all phone or tablet app.
Here's a Denon that has HEOS built-in for its streaming control - Amazon: https://rebrand.ly/8dsrvpi
It has A/B speaker selectors and XM. It also uses TuneIn for Internet Radio and is Roon tested. I don't know enough about HEOS to know if its built-in nature makes it more reliable. From what I can gather, it does not cast from an app, although you can use the app to set up the built-in HEOS on the receiver. It has HDMI, which I'm not sure would help with HEOS or not... may still have to have an app on a phone or tablet.
Musicast is rated 4.4 in the app store vs 3.8 for HEOS.
Does anyone use Musicast or HEOS in their receiver?
