A simple question I think
Badbruno
ExaSound S88
Polaris Audio
Polaris Audio
Polaris Audio
ExaSound S88
Mac mini and IMac 27
VPI Prime turntable
Roon
Roon Quobuz
Custom open baffle 3 way
Velodyne DD12+
So Im measure a 2.1 system. Im using REW, My question is Ive been taking three measurements on the left channel then average those three. Next, take three on right right channel and average those three.
From there I use EQ to build filters for each channel Right and left to load into my DSP.. Is this the correct workflow? or should I be taking some Stereo measurements?
thanks
Badbrunbo
If your speakers are symmetrically placed left/right and the room itself is symmetric left/right then some resonances that appear when driving either speaker alone will not be present when both speakers are driven together (odd order width modes).
Badbruno
ExaSound S88
Polaris Audio
Polaris Audio
Polaris Audio
ExaSound S88
VPI Prime turntable
Roon
Roon Quobuz
Velodyne DD12+
Thanks John
The speakers are symmetrical but room is not with a vaulted ceiling.
One side of the room is completely open to another room. The other three sides are made up of glass windows in the “sunroom”
