I just downloaded the latest REW and found the measurement trace also shows the mic. Although calibrated it is not flat. Actually it is pretty straight but slopes down. Is there any way to adjust the measured response for the mic?
The mic trace is simply the view of the calibration file you've loaded when measuring. "Not flat" would be expected for a calibration, otherwise it doesn't do anything.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
