Steviewunda
- May 10, 2020
- 17
Hi - I'm a new user of REW with 5.2 speakered Denon receiver, MiniDSP 2x4 HD, 2 x different but similar 12" sealed subs. I would really appreciate anyone checking out my attached .mdat file and advising me how to improve on the result I currently have. The subs have been gain-matched, time-aligned and eq'd in REW then sent to the MiniDSP, and I'm hoping someone more experienced can suggest a way to boost the 20 - 100hz region, and to smooth the curve more. And i'd be grateful if someone could explain how to do a full range measurement using ASIO drivers instead of Java - the Asio drivers are easier to use for sub measurements (I dont have to raise crossovers, etc on the receiver), but I can't see how to do a full-range measurement using ASIO drivers. (You'll see that I changed to Java for the last 2 full-range measurements). All suggestions gratefully received
Cheers
Steve
Cheers
Steve
