couch
- Mar 5, 2022
- Messages
- 3
- BAT VK-90
- Main Amp
- BAT Rex3 monoblocks
- Other Amp
- BRZHIFI Hood 1969 Class A
- DAC
- exaSound e62
- Computer Audio
- Mac Mini 2015 with UPtone LPS/fan controller. JRiver software
- Streaming Equipment
- Cambridge Audio CXN v2
- Streaming Subscriptions
- Amazon Prime video, Netflix, Criterion Collection
- Von Schweikert VR 44s, Townshend seismic bars
- Other Speakers
- Heavily modded Optimus LX 5s
- Video Display Device
- LG 40" 4K UHD OLED
- Other Equipment
- Synology NAS on CyberPower pure sine UPS
I'm new to REW and successfully making nearfield and farfield measurements to baseline some speakers prior to tracking mods. Following napilopez's good guide in Audio Science Review for quasi-anechoic measurements. My speaker is a mini-monitor with a 6.25" nominal woofer and two 0.5" ports that flare to 0.75." I am ready to apply offsets to align near field LF SPL plots of ports and woofer and then plot the aligned sum, which I will then want to splice into my 1 M farfield trace. Napilopez's guide shows an REW "alignment tool" under the controls menu with several available actions including sliders/text fields to apply offset for the port SPLs and a summing button. I don't see any of those things under the controls menu on my free copy for the Mac. Is this a Windows-only feature, a pro upgrade feature (happy to upgrade if so), or am I looking in the wrong place?
Also, how do I work with the three separate traces in the one window to do this manipulation? Napilopez shows a screen shot but doesn't say how the traces got there. Does the overlay window work for this if the alignment tool is present, or do I treat them as multiple inputs (I'd prefer not to do the measurement again if I can avoid it)?
Thanks for any insight!
- couch
- couch
