(January 15, 2025) Ascendo has introduced its AIA2-10K2 IS amplifier, a solution designed to tackle a challenge in home theater audio: delivering consistent and powerful performance at extremely low frequencies. The demands of modern home theater setups, with their focus on immersive soundscapes and dynamic bass effects, often expose the limitations of traditional amplifiers. Whether in home theaters or commercial applications, many amplifiers struggle to sustain output in the sub-20Hz range, a critical area for delivering the full impact of low-frequency effects.
Traditional amps, especially those designed for public address systems, are often optimized for short-term power bursts. These designs prioritize portability and efficiency, delivering peak performance in quick, 20 to 40 millisecond bursts and rarely focusing on frequencies below 35Hz. While this approach is effective for concerts and live events, it falls short in home theaters, where consistent and sustained power is essential. Even home theater amplifiers, while better suited for lower frequencies, frequently rely on lightweight power supplies and lack the ability to maintain voltage stability under prolonged heavy loads. This results in a loss of clarity, impact, and depth in bass reproduction, detracting from the overall experience.
To address these issues, Ascendo developed the AIA2-10K2 IS amplifier, engineered to deliver continuous, stable power across all frequencies, including those as low as 3Hz. This amplifier’s fully balanced design ensures consistent performance under demanding conditions, eliminating voltage sag and maintaining output even during extended playback. The higher damping factor improves bass control, enhancing extension and clarity while delivering the kind of detailed and impactful low-frequency performance that is crucial for home theater enthusiasts.
The amplifier’s design reflects a commitment to reliability and functionality. Its robust construction and advanced cooling system allow it to perform consistently during extended use, ensuring it can handle the rigors of high-output, bass-heavy content without faltering. While specific dimensions and weight have not been disclosed, the AIA2-10K2 IS is billed as built to meet the needs of serious home theater installations.
The AIA2-10K2 IS amplifier will make its debut at ISE, where more information about its specifications and capabilities is expected to be revealed.
Relating Reading:
- CEDIA 2024: Ascendo’s Mastermind Explains Secrets of Infrasonic Bass, Dives Deep Into the New The28 Infra-Sub!
- Ascendo Drops an Infrasonic Bombshell with Groundbreaking The28 Sub Squared Pro, Adds The 16Sub Pro Passive to Lineup
- Ascendo's Second CEDIA Surprise is Revealed: The10 Passive LED Phantom Voice
- Ascendo's New Director LED Wall Loudspeaker System Launches, Destined for CEDIA Debut
