Alexander Fischer
- Jul 22, 2018
- 4
Hi,
I have REW v5.19 installed on my Windows 10 PC. My audio interface is a Universal Audio Apollo Twin MKII Duo connected on a USB-C port with a Thunderbolt 3 to Thunderbolt 2 adapter. The installed ASIO drivers work fine with my DAW (Cubase 10) and several other stand-alone audio instruments. However, when I try to select the ASIO driver in REW it only shows the USB and Firewire options for the 'siblings' of my Thunderbolt 2 interface. No thunderbolt options selectable if 'ASIO' is selected. When I choose the Java driver option and select the Windows WDM drivers for my device, the calibration doesn't work properly. The generated sine sweep wave doesn't look right and the response measurement delivers a wrong frequency response of the audio interface (see attached screenshots). I thoroughly followed each step of the help file.
Am I doing something wrong or does REW not wortk with ASIO drivers for Thunderbolt devices? Can the 48 kHz sampling rate setting in my interface be a problem?
Thanks,
Alex
Thanks,
Alex
