rodelius
- Dec 3, 2020
- 7
- Joule Electra LA-150
- Main Amp
- Krell KSA-50S
- Additional Amp
- Ars-Sonum Gran Filarmonia
- Other Amp
- Bryston 4BSST
- DAC
- Auralic Vega
- Computer Audio
- Mac
- Meridian 588
- Merlin VSM
Got a good deal and purchased a Behringer UMC204HD interface to replace my old M Audio Fast Track Pro. Main use was and will be occasional measurements with REW.
Despite the UMC204HD not needing drivers for mac, I have found it impossible to make it work well with REW on any of my Macs, all of them running Mojave and the latest version of REW. Although at some point I was able to perform an i/o loop measurement of the sound card itself at 44.1 but the card seems unstable and inconsistent in its operation. And somewhat noisy.
Being in the return period I have chosen not to use the cable that comes in the box and I have powered it from the USB ports of the computers and not from a powered hub. However, my old M-Audio works fine in the same conditions, albeit only at 44.1.
With itunes the UMC204HD works fine.
If anyone who has used it to measure with REW on Mac can provide any ideas I’ll give it a chance, otherwise what soundcards is a good option for Mac nowadays?
TIA
TIA
