Can anybody say where the difference comes?
S Simple Man Registered Thread Starter Joined Oct 20, 2022 Posts 4 Oct 20, 2022 #1 Can anybody say where the difference comes?
John Mulcahy REW Author Joined Apr 3, 2017 Posts 8,174 Oct 20, 2022 #2 Pretty odd. Was phantom power turned on for the Behringer?
S Simple Man Registered Thread Starter Joined Oct 20, 2022 Posts 4 Oct 20, 2022 #3 Yes. I tried with two different souncards, same result with both. One is focusrite solo and another is Audient Evo4.
S Simple Man Registered Thread Starter Joined Oct 20, 2022 Posts 4 Oct 20, 2022 #4 If I would have another phantom power mic, it would be easy to check if mic is defected.
