Big volume difference between L and R channels in 'check levels' and 'mesurement'.
Dox82
Hello,
Today I tried to do a mesurement for a friend of mine using its setup with a USB UMIK-1 and a Tone Bone DAC connected to an Atom Unit.
The "Check Levels" procedure is fine with an "In" dbFS of 43dbFS for 80dbC mesured with an SPL meter at the mic position.
Unfortunately, doing a "Check Levels" into "Measure" window I see 79db for the L channel (ok, compatible with the "calibration") but 87db for the R channel.
If I do an L+R "Check Levels", in the same windows, I have 87db again.
Can you tell me what could be the cause of this (big) difference? Abviously, doing a "Mesurement" for L and R is easy to se the big difference in levels between two channels.
Many thanks!
Bye
