Andrea Tarasconi
- Aug 4, 2017
- 3
Hello,
I am using REW 5.20.5 to correct my system room response. I have a 2-way stereo active solution with cross-over at 60Hz (18" sub...).
As player I am using JRiver MC28 and Foobar 1.6.10, as cross-over I am using Thuneau Allocator and as convolver the MeldaProduction MConvolverZ.
First I measured the response of the system alone, then I generated the impulse filter and finally I measured again the response of the system with the correction.
What I detected is that the response after the correction (convolver applied) was having big problem over 1kHz, so I simply decided to disable all the EQ filters above 1kHz and so I go finally a decent response.
However, looking at the measured responses, simulations and final results, it is evident that there are too many deviations. I think there is a bug or at least a strange measuring problem.
Index of measurements in the attached files (containing also the embedded EQ filters generated and settings):
* measures 1, 2 and 3 => just 3 repetition of the same full system response at the golden spot (crossover only with phase alignment between sub and sat). NO Convolver.
* measure 4 => time alignment and averaging of the above 3 measurements to be used to generate the room EQ filters.
* measure 5 => import of the above made filter impulse response (just to give it a look)
* measures 6 and 7 => 2 times repeated measure of the full system response at the golden spot with the applied EQ filter / Convolver => To be noted the bad / over-busted response from 1kHz to 7kHz
* measure 8 => import of the manually modified filter impulse response where I removed the EQ filters 6,7,8,9 - All the filters generated above 1kHz (just to give it a look)
* measure 9 => finally obtained good response using the #8 filter for convolver... However, even if it is looking nice and flat, it is not the response I have planned as target in my design (I set a 5dB roll-off at 20kHz that is not there)... This is really a flat-flat response.
Anyone can help me understanding what's going on?
Thanks and regards, Andrea
