Calibrating SSL2+ and Presonus PRM1
santiagoabelleira
Hi all, I am trying to calibrate my sound card to make some measurements but I am not sure if the result is correct.
I am connecting the out to the in and cranking the monitor level until -12dBFS however I am not very convinced with the curve obtained, it seems pretty whacked. I have also attached the measurement file, any help would be greatly appreciated.
Monitoring is active so the input is being mixed back to the output. The output has to be only the signal from REW.
