I have been having some difficulties getting consistent calibrated measurements. For example I have a set of two different measurements done on two different days that look exactly the same as far as cal settings, but show up around 20 dB different.
Same "dBFS @ 94 dB SPL" setting, same mixer settings, inputs, outputs and DUT same.
My procedure was to calibrate using the SPL meter (external source) and an acoustical calibrator, all set to 94 dB SPL. Is this a sound way to calibrate, and is there some other way I might have gotten this offset within REW?
See below. Measurements are not exactly the same in every way but...
I should add that the 154 dB data offset and the corresponding -57 dB sensitivity arising from my calibration is very very close to what I calculate knowing the sensitivity of the MEMS mic being measured.
