tannerupthegrove
- Jul 1, 2022
- 7
When calibrating a soundcard with a multichannel input:
- Should each input have a separate calibration file or does the calibration for an input get applied to all input channels?
- If each channel gets an individual calibration file, where is that applied? Is there a way to sequentially add them in either the Soundcard or Cal Files in the Preferences menu?
- I also have Mic calibration files which are applied to individual channels Preferences > Cal Files
- [Gain Staging] Class 1 Calibrator 1kHz @ 94dB with adapter > Earthworks M23 Microphone > RME Mic12-D Preamp with output over Dante > REW SPL Meter dbA SPL Fast > adjust RME Preamp until SPL Meter reads ~94 dbA F
- Remove Microphone for REW Calibrate Soundcard... -12dbFS 1kHz sine wave > RME Mic12-D Line Level Balanced Output 1/4" M Balanced Cable > XLRM on RME Mic12-D Input 1 > Adjusted the line output to match the -12dbFS test tone within +/- 1dB then run the sweep
- Make Cal File... from measurement
- Calibration applied (to only channel 1 of the soundcard or all?)
- Preferences > Cal Files > Check Yes for Separate Cal for Each Input > Select appropriate Earthworks Calibration File for each input
- Reconnect Microphone and calibrator and validate the 94dbA F in SPL Meter, repeat if needed
