neodog
- May 3, 2024
- 22
- Computer Audio
- Focusrite Scarlett Solo
- Other Speakers
- ECM8000 mic
The manual has this to say about FFT length:
Is the overlap % the amount of the block overlapping, or is it % not overlapping? I ask because I get the slowest computations setting Max Overlap to 0%, and the fastest computations setting it to 93.75%; the values in between follow this pattern. This is exactly opposite of what I would expect: more overlap should mean more computations. It's almost as if the drop-down values have the reverse their intended ids.
And about Max Overlap:As the FFT length is increased the analyser starts to overlap its FFTs, calculating a new FFT for every block of input data. The degree of overlap is 50% for 16k, 75% for 32k, 87.5% for 64k and 93.75% for 128k.
The spectrum/RTA plot can be updated for every block of audio data that is captured from the input, overlapping sequences of the chosen FFT length. This can present a significant processor load for large FFT lengths. The processor loading can be reduced by limiting the overlap allowed using this control.
