Jas0_0
- Oct 13, 2018
- 11
- Croft 25R
- Main Amp
- Croft 7R
- ProAc Response 1SC
Hi all,
This is my first post here. I'm just realising the potential of REW and my iMac as a room measurement/correction device in my stereo setup and wondered if you could help me with something.
My DSPeaker Anti Mode 2.0 exports both 'before' and 'after' room correction measurements that can be loaded into REW (files attached).
I wondered if there's a way to use these measurements in Audirvana (maybe using REW and an AU plugin?) - allowing me to remove the Anti Mode from the signal path and play high res music at native sample rates, rather than them being downsampled to 48kHz by the Anti Mode.
Is there a way to do this?
Many thanks in advance,
James
James
