Hi,
I posted this in another thread but did not receive a reply. So, I am trying it in a new thread.
I have relocated one of my subs, so I am trying again to align my two subs (HSU's; one ported and the other sealed). I have an Emotiva UMC-1 processor, with a 5.2 setup and minidsp 2x4HD. I am trying to understand the relationship between good SPL and what is a good phase response. There seems to be multiple delay settings that look good when moving the sliders.
Determining the best one is where I could use some help.
Measurements of the subs, mains and center are attached.
This is what I understand to perform 2 Sub alignment:
1. Use R sub base 200Hz XO and L sub base 200Hz XO (measurements with XO set to max =200Hz).
2. Use the slider to find the smoothest response, preferably with the summed output above the individual subs output. Question: while doing this, what should I be looking for from phase response, all 3 lines to converge and overlay each other?
3. Once I find the correct delay, click on align sum.
4. Re-measure both subs with XO's set to max to verify it and the aligned sum measurement are the same.
These are measurements before delay is applied. Except for the dip between ~35-50 Hz. I thought it looked okay.
3 sec delay set on slider. Smoother response, however SPL is below individual sub measurements at some frequencies. Not sure what the phase is telling me, though.
-16.34 sec delay set on slider. Not as smooth, but good SPL. This seems strange since the right sub is closer to MLP (~7ft. vs. 15.6ft for the left sub. Is the graph indicating the 3 lines are in phase (or close to it, from 40 - 120Hz?
I appreciate any help in sorting this out. Once I get the subs aligned properly, I will move on to aligning mains with subs.
