Edge of No Tomorrow 4K UHD.... Bass?
Editor / Senior Partner
Baltimore/Washington Metro
Kaleidescape TERRA
OPPO UDP-203
Panasonic UB9000
Spotify
GoldenEar Invisa MPX
Quad Array SVS SB16s
JVC NZ8
Sony 65-inch A95L OLED
Sony 65-inch X900F
ZeroSurge 8R15W x 2
ZeroSurge 2R15W x 2
As the 4K Dolby Atmos Version of Edge of No Tomorrow hits the streets on July 5, a lot of enthusiasts are bracing themselves for a bit of a let down on the low-end side of the audio equation.
I did a quick comparison of the original BD release and the K-scape 4K version, and found that the infamous opening bass notes have been altered (read: changed for the betterment of systems across this great land ouf ours!).
If you can see a visualization of the two versions, here:
As you can, the super deep infrasonics have largely been scratched. That said, the Atmos track is rock solid!
Disappointing. I would have thought it would have been improved not reduced.
Definitely disappointing but I will most likely still buy the 4k in the future for the atmos.
