(March 16, 2022) On the heels of releasing its Pro Cinema LS12000 4K Laser Projector, Epson is launching an all-new top-of-line Home Cinema model, the LS110000. Much like the LS12000, the LS11000 uses 1080p imagers and a Precision Shift Glass Plate pixel shifting system to display 8.29 million individual pixels on screen. The result is nearly indistinguishable true 4K image quality. A converted blue laser light source is distributed to red, green, and blue LCD chips, eliminating any concern of rainbow effect visual artifacts. Epson says the light source is capable of 2,500 ANSI lumens with a total life expectancy of 20,000 hours.
The LS11000 has a dynamic contrast ratio of 1,200,000:1, supports HDR10, HDR10+, and HLG High Dynamic Range, and utilizes a 3-Way Motorized Lens for precise shifting capabilities (+/- 96 percent horizontal, and +/- 47 percent vertical movement). A 16-step HDR curve adjustment fine-tunes HDR performance, while a newly deployed Picture Processor can provide real-time picture quality adjustments on a frame-by-frame basis.
“A 65-inch flat panel isn’t cutting it when it comes to achieving total immersion in today’s stunning movie and gaming experiences,” said Rodrigo Catalan, group product manager, projectors, Epson. “If you’re looking for a 4K HDR home theater and gaming experience that will exceed your expectations, the Epson Home Cinema LS11000 is one of the best Home Cinema projectors Epson has ever made.”
The Home Cinema LS11000 is priced at $3,999.00 and is expected to begin shipping later this month. For more information, read Epson's release notes (below) or visit the LS11000's product homepage.
Additional features include:
- 4K PRO-UHD1 – Advanced pixel-shifting technology works in parallel with three individual high-definition LCD chips without sacrificing picture brightness
- Precision Shift Glass Plate Technology – Unique, digitally controlled Precision Shift Glass Plate precisely refracts pixel light to display a 3840 x 2160, 8.29-million-pixel image on screen for an exceptionally sharp and clear picture
- Epson Picture Processor – Powerful video processing technology, the proprietary Epson Picture Processor handles real-time color, contrast, HDR2, frame interpolation and resolution enhancement
- Laser Array Light Source – True multi-array laser diodes are the optimum light source to power the unique 3-chip 3LCD projector engine for incredible picture brightness, black contrast and color accuracy
- High Picture Brightness – Impressive 2,500 lumens of color and 2,500 lumens of white brightness3 for an exceptional picture in virtually any theater environment – even in rooms with some ambient light
- True 3-Chip 3LCD Projector Engine – Advanced 3LCD technology uses three individual LCD chips to continuously display 100 percent of the RGB color signal for every frame; this allows for outstanding color gamut while maintaining excellent brightness without any rainbowing or color brightness issues seen with other projection technologies
- Impressive HDR2 – Full 10-bit HDR2 color processing accepting 100 percent of the HDR source information to faithfully reproduce HDR, HDR10+ and HLG (Hybrid Log Gamma) content for an exceptional visual performance; real-time HDR curve adjustment allows for 16-steps of control to finetune the HDR performance regardless of the content
- 120 Hz Refresh Rate – Refresh rates up to 120 Hz allow for smoother motion for supported content while providing the option for impressive Frame Interpolation for content below 120 Hz
- Impressive Contrast – Taking full advantage of the Laser Array Light Source, Epson is able to suppress stray light within the signal and enhance the picture contrast to produce a Dynamic Contrast Ratio exceeding 1,200,000:1
- Epson Cinema Lens – Designed for zero light leakage, the Epson Cinema Lens utilizes a proprietary multi-element precision glass structure for outstanding image clarity and edge-to-edge focus uniformity
- 3-Way Motorized Lens – Making installation simple, you can precisely shift the lens up to +/- 96 percent horizontally and up to +/- 47 percent vertically without picture distortion or loss of clarity; you can also set the zoom and focus, then store all the settings in one of ten lens memory presets
- Real-Time Scene Adaptive Correction – Powered by the Epson Picture Processor, the user has the option to automatically adjust the picture quality based upon the scene information itself; this provides a simple way to get impressive color and contrast, regardless of the content being displayed
- HDMI® 2.1 – Supports the full 48 Gbps bandwidth for accepting uncompressed 4K HDR2 content up to 120 Hz; along with ARC and eARC support, this allows for outstanding compatibility with the latest AV receivers and next-generation gaming consoles
- Epic for Gaming – Gaming up to 4K at 120 frames per second, along with input lag times below 20 milliseconds, allow serious gamers to take full advantage of the latest generation of gaming consoles and even higher-end gaming PCs
