REW Beta Release Error when generating minimum phase IR
greatadrian
Hello,
I noticed that when trying to generate a minimum-phase IR there is an error.
It occurs in REW 5.20 RC2 & RC3 (running on MacOS).
The error message:
Code:
REW V5.20 running JRE 1.8.0_252-release 64-bit on OS X 10.16, en, , UTF-8 at 127 DPI
Message:
Stack Trace:
    roomeqwizard.aI.K(y:1292)
    roomeqwizard.aI.œ(y:1914)
    roomeqwizard.aI.F(y:1234)
    roomeqwizard.rA.ë(y:2775)
    roomeqwizard.rA.D(y:2206)
    roomeqwizard.rA.C(y:2072)
    roomeqwizard.rA.propertyChange(y:1338)
    java.beans.PropertyChangeSupport.fire(PropertyChangeSupport.java:335)
    java.beans.PropertyChangeSupport.firePropertyChange(PropertyChangeSupport.java:327)
    javax.swing.event.SwingPropertyChangeSupport.firePropertyChange(SwingPropertyChangeSupport.java:92)
    roomeqwizard.MeasData$7.run(y:2688)
    java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:311)
    java.awt.EventQueue.dispatchEventImpl(EventQueue.java:764)
    java.awt.EventQueue.access$500(EventQueue.java:98)
    java.awt.EventQueue$3.run(EventQueue.java:715)
    java.awt.EventQueue.dispatchEvent(EventQueue.java:734)
I attached the project for which generating MP IR will fail. As an example, I imported measurement sweep against itself.
Many thanks for your hard work John!
  • example_project.mdat
Wish I had seen that yesterday. I have fixed it for the next build, in the meantime the bug can be avoided by generating the min phase response from the SPL & Phase graph rather than the Impulse graph.
greatadrian
Sadly, I noticed it only yesterday evening. I did also notice that similar error happens when MP Impulse Response is selected during WAV export. Not sure if it’s related.
Many thanks for looking into that!
