Ratterbass
- Jan 25, 2024
- 14
It would be nice to be able to set the unit for a measurement at will. Especially when importing data from a .csv file.
If I for example import impedance data from a .csv REW won't let me chose the Ohm unit for the data set. Instead it will assume I imported levels and when I click on Ohm in the unit drop down menu it will default back to SPL. It would be nice if at least for imported data if it were possible to set a unit for that dataset and REW stick with it.
It would also be nice to be able to set custom/arbitrary units for the dataset. REW has some really nice data manipulation and plotting features so it's actually a really handy tool for data other than voltage, SPL and impedance.
Example: I have a setup where I take impedance measurements but instead of using the built in method with reference resistors I have two channels, one with the voltage and the second one has a current sensor so the input data corresponds to the signal current. It would be nice to be able to set the unit for this second channel to Ampere also with its individual full scale calibration setting to that the levels are correct.
Thanks!
Thanks!
