HuibertBoon
- Aug 14, 2024
- Messages
- 5
- Additional Amp
- Amsterda
About EQ>Filter Tasks> Match Range ...
The manual states "The Match Range defines the frequency span over which REW attempts to match the target response, and within which filters will be assigned."
That would mean that you select the freq-range of the speaker you've set in the Target type So: 20-20K for Fullrange, 80-22K for basslimited, 20-200Hz for Subwoofer, based on the specifications of the speakermodel. (No need to calculate filters outside the frequencyrange of the speaker...)
But then the manual continues with the following:
"REW can apply filters anywhere across the band, but it is usually best to limit filters to low frequencies (less than 200 Hz or so) unless you are compensating for some general characteristic in the speakers (an example might be a dip in the mid range or a bit too much HF) - that is using EQ as a fancy tone control."
Does this mean that the term 'Filter' is used in 2 different meanings: as only LP, LS, HP and HS under Match Range, but as all type of filters (including PK and Notch) like under 'EQ filters' and 'Allow narrow filters below 200Hz'?
