First Attempt with REW, I have questions
scott180
For starters, I followed David Brancato's videos. Because of the detail and the length, I made a step by step list of things to do. It ended up being four pages long and I used that for my first test.
I have a set of speakers I built using a kit from Parts Express.
The main question I have relates to phase. I used rePhase and then created the FIR filters. I have a QSC Core 250 that is handling the processing. One difference between the video and what I did is that I set the taps to 1024 to keep the delay to around 10ms. The initial phase trace wasn't terrible. But when I did a final measurement after adding in the FIR filter, the phase wrapped around 100 times. That wasn't expected and I'm sure I did something wrong. Pictures below of the initial measurement, the predicted result, and the final measurement.
Initial (7 position average)
Predicted
Actual measurement with FIR filters
Because I'm new I can't post a link to my instructions or the video
sm52
When the mouse pointer is on the SPL graph field, click the right mouse button, and Estimate IR delay, Shift and update timing offset.
scott180
Got it. Thank you. Just so I grasp what happened, the 10ms of delay from the FIR filter caused the IR timing offset. I had a loop back into REW for timing purposes so the reference loop back and measured responses were not aligned causing the phase trace to show that.
Here is the adjusted view with the new IR alignment:
scott180
If anyone is interested, here's the instructions I pulled from the David Brancato video
  • REW to QSYS FIR filter creation.pdf
moedra
I'd like to see how you broke it down, but your link isn't working for me. Have the videos been working out for you? I'm glad you found them. I must admit I made those a while ago and have learned a lot since then.
