Fonts that are not displayed properly
sigotnin
Please tell me the correct font to display this software
windows10 environment
33416
Use the latest beta version and device names should be displayed properly. Incorrect rendering of non-ASCII audio device names is a bug in the Java runtime, but the beta versions have a workaround that fixes the bug.
In the latest beta version, it is not displayed correctly or cut off halfway.
maybe,
Cut in the middle of multibyte character.
33430
Can you add a screenshot of the About REW dialog?
If the Windows option to use UTF-8 for worldwide language support is selected check the "Using unicode UTF-8" box.
Thanks. You my be able to get correct display by selecting the Windows option called "Beta: Use Unicode UTF-8 for worldwide language support" in All Settings -> Time & Language -> Language -> "Administrative Language Settings", but that might cause problems with other applications. I'll look at updates for the next beta release to try and extend the bug workaround for Japanese fonts, I may contact you via the forum messaging system to try out a test version if that is OK?
