I have not used my laptop with REW and MiniDSP 2x4 HD in years. How can I check what the polarity suggested for me when I last run it? I have flipped the polarity so many times using all sorts of calibration apps that I have forgotten which is which. I want to know what it set it to in the when i first did my calibration with REW.
Also, is there a way to toggle between no setting to settings that are currently in the MiniDSP? (I want to try without alignment, or phase, etc.)
I would really appreciate your help. Thank you.
