user44455555
- Jan 16, 2021
- 146
I mean seem no room problem. I measure 1.5 cm away. and the focal alpha 65 with the carbon fibre(they call it slate fibre) woofer/mid have this problem not. Both are 6.5 inch speaker measure on same day on same stative position and 1-1.5 cm near. the focal soiund amazing and is on other level of 6.5 inch speakers woofer mid, but i see there can be much more enhance. i test with a transient enhancer in range 150-500 hz and i notice more clarity and punch which is then exactly on headphone. the bass feeling reach from 150-200 hz
there can calc and see that when measure 1.5 cm away and the nearest wall(desktop) is 40 cm away (which is 80 cm because sound need go to desktop and back) then level is 35 db less. so the room seem not the problem of this large overshoot of the Kali
is there a way in REW software to see if the overshoot is larger as the signal ?.
the mesaure tone 400 hz. I test in DAW. signal is not very loud. only around 65 db at 1 meter. on top the 52 mean seconds. and scale is that 1 vertical line is 1 ms
Kali LP6 1. wave result
Foal Alpha 65 evo
superlux 686 evo put on desktop and measure in the middle of system 1.5 cm away. distance to desktop is 7 cm then. the overshoot can maybe larger because of reflections. even if not the headphone is a cheap model and cost around 30 $ and have best 1 positive peak level in my compare
the burst measure tones can download in this message and are bar align. they contain 100 hz, 400 hz, 800 hz , 1.4 khz, 2 khz, 3.5 khz. tweeter test i have not add, tweeters are much better. the strange thing is the kali do less overshot when test 800 hz or 1.4 khz. close bassport i test on all speakers. does not help . on 100 hz speakers do more overshot also the headphone. but the headphone is always much better
thats strange. I thought overshoots are more when come more near the maximum frequency of a system. that there on low frequency are so much problems in speakers is really bad because the room have longer reverb and so reverb the overshoots too
Sound level distance damping decibel dB damping calculation calculator change distance versus sound level apps reduction drop dissipation SPL sound transmission loss free field loss sound and distance - decrease drop fall sound over distance versus d
Sound level distance damping decibel dB calculator calculation change distance versus decibel dB decibel sound level apps drop dissipation SPL sound transmission loss damping calculation loss sound distance sound reduction free field decrease fall drop attenuation sound over distance versus dB...
www.sengpielaudio.com
Foal Alpha 65 evo
