Inter-channel Timing Offset
mfinzi
Greetings, l just got to setup my REW measurement jig consisting of resistive voltage divider and back to back 3v9 zener diodes. Adjusted the levels using rew to control the levels using a left channel loopback, then connected my jig through a 4 watts amp. When l attempt to calibrate the measuring system, this is what l get: A timing offset of 0.02 samples was detected between the measured and reference channels. What did l do wrong, are the resistors on the divider network also non-inductive or could it be the 33 ohm current sense resistor. My desktop is operating on windows 7 ultimate and RAM 3gig. Regards
Mfinzi
