Is it possible to set the Average using the RTA higher than 32 ?
hemiutut
I like to equalize at the end the RTA but the maximum I see is an Average of 32.
and the frequency bars still move too much.
In a next REW update will you be able to apply an Average of 64 and 128 for example ?
I leave a video of my center channel
Written with translator
Greetings
hemiutut
Use Pink Periodic Noise with a sequence length that matches the RTA FFT length, then you won't need averaging at all. Use a Rectangular window in the RTA.
Thank you John for the courtesy of replying.
I was using Pink Random Noise, I just tested it at 128 and 256k
and it is what I was looking for.
Regards
