Java problem in REW
SA3TVF
Trans-SE18
Lynx22
LINN Akurate
Linn Akurate
Lowther
Hi,
When I run "stepped sine" I got this error message
When I click 'Close' (Stäng in Swedish) . The error message is repeated a 3-5 times. but after these repeats the "stepped sine test" continue and run all the way to its stop frequency.
The result of the test seems okay as far as I can see, but I'm unsure. I have not seen this Java error message in any other use of the REW
I have attached a file with the details from the error message.
Any idea what can be wrong in my environment?
Best regards,
Tord
  • JAVA_ISSUE.txt
It's a bug that has been fixed in the current beta version. You can avoid it by enabling the distortion HP limit or by selecting to use the AES-17 standard notch in the distortion settings.
SA3TVF
Trans-SE18
Lynx22
LINN Akurate
Linn Akurate
Lowther
Thank you very much for the information:)
