climbclimb
- Mar 21, 2025
- 4
- Main Amp
- purifi 9040sa
- DAC
- topping d90
Audiolense made some great filters for my last speakers (thank you, Mitch). Now trying it on my own for new laptop+speakers.
When attempting to run sweeps through audiolense 6.21, I'm seeing very low output from the speaker (maybe 70dB) Measurement setup is windows, UMIK-1 microphone, to toping usb dac. I'm using WASAPI (both mic and output).
Things I have already checked:
System can play (music in jriver) very loudly, so it's not that.
Amps on high gain, but not enough.
Adjusting windows volume doesn't change anything.
mic set to the max level in Audiolense(0dB).
Is there some adjustment I can make the sweep amplitude? Alternately are there some factors I can adjust which then affect the amplitude? Thanks!
