Maintaining constant amplitude with bandwidth limited pink noise
dcibel
Hello,
This is hopefully a stupid question. Is there an easy method to maintain equal amplitude when limiting the frequency bandwidth of pink noise using the generator? For example, If I set 90dB SPL for a "speaker cal" signal that is limited to 500-200Hz, then change to a full range signal, SPL of the full range signal is reduced even though the output level is the same. I assume the variation is due to the fact that pink noise is not constant power over frequency, so can the level be set for -12dBFS at 0Hz even though the signal is limited to 500Hz and up?
Simple example below. I would like to complete some bandwidth limited testing using pink noise, but without the shift in amplitude. As it is, I am making some manual adjustment in level for each filter applied on the generator, and I have to think "there must be a better way" :)
Thank you.
The spectrum level changes to maintain the requested rms level over the narrower bandwidth. I am currently working on another measurement method which provides a post filtering option for the excitation, so the spectrum stays at the same level in that case.
That's great news John, exactly what I'm looking for.
(While looking at measurement methods, periodic noise in the measurement window? 😉)
