MantelMount Adds to Its Versatile TV Mount Lineup with the MM720 at CEDIA 2022
(October 11, 2022) MantelMount arrived at CEDIA 2022 with its all-new MM720, the latest addition to the company’s line of Pro Series pulldown TV mounts. The MM720 replaces the company's MM710, but costs the same, making it MantelMount’s most versatile pulldown model. It features a new tilt mechanism, additional handle options, and an extended swivel. The MM710, which was formerly part of the company’s Pro Series, will now move to MantelMount’s Consumer Series but is still available exclusively to MantelMount dealers.
A patent pending tilt function stands as a highlight feature of the MM720. Because it allows direct tilt access from the front of the TV, the MM720 can be tilted from below even when the TV is high up on the wall. To adjust, the owner simply squeezes a handle at the bottom of the TV and pushes or pulls the TV to adjust the tilt (up to 9 degrees). Releasing the grip from the handle locks the tilt angle in place. It makes tilting the TV especially convenient; no other TV mount offers a tilt function that works in the same way.
Owners have the option of selecting a Hideaway Handle or a Heat-Sensing Handle for pulldown operation. The Hideaway Handle remains invisible from the front of the TV, creating a sleek and professional-looking installation. The Heat-Sensing Handle turns red if temperatures reach 110°F.
The included SRE00 Side Swivel Kit gives the MM720 an extended swivel range of up to 80 degrees in both directions, allowing for television viewing from an adjacent room. along with a vertical drop up to 27”.
We caught up with MantelMount's Remy Kale, learned about the MM720, and received a hands-on demonstration. Watch the entire interview and demo, below.
