Mini DSP & rePhase for FIR Phase correction
Foly83
Germany
Marantz AV-8805
Emotiva XPA 3, 2x Emotiva BassX
Bowers &Wilkins 804D3
HTM1D3
Cinema Series
Cinema Series
Cinema Series
4x DB1
Mini DSP 2x4HD, DDRC 88-BM, Mini DSP Thomann 4x4
Hello friends of good sound
I would like to create an FIR filter.
The last time was about two years ago, it's hard to remember.
Is there now a simplified way to create a file for rePhase in REW?
Or a thread that explains it in detail that I can't find?
I would like to open the measurement data untreated in rePhase and only correct the phase.
The whole thing for the Mini DSP 2x4HD system
I would be very happy about help :)
Alex
I'll try again.
This time with an example.
And upload a measurement. I've been trying for days, but it doesn't work.
Maybe someone can explain how to do it based on the measurement?
Just a channel for testing.
Or does someone have a working method that is explained in a post?
My procedure
Channel measurement without FDW no smoothing
Multi-point measurement Align via cross corr align
Switch to Psy
db average of the respective channel
vector average of the respective channel
MP of db average in spl&Phase
MP from vector average in all SPL
EQ from db average and save as file for rePhase
EQ of MP Vector average for GD adjustment left and right channel
EP from EQ MP Vector average
MP from EQ Vector export as txt for rePhase
rePhase open XML and load txt
export as wav for review
export .bin for DSP
What am I doing wrong
help :dizzy:
Best regards
Hi... You might get a few ideas from this thread... https://www.avnirvana.com/threads/convolution-room-correction-and-room-curve.14005/
Paying special attention to posts from moedra... This technique does not use rePhase...
And his full tutorial at https://nverxion.wixsite.com/meridiansoundworks/drc-rew...
If I remember correctly the video by AOC in the first post has a section where rePhase is used... There are written instructions pointed to in the YouTube comments which may be of help... Or some of AOC's other videos my have some hints more specific to your kit...
Many thanks for the information. :T
Your welcome... Hope you find something of use for your kit...
