Monoprice is Set to Rock CEDIA 2017 with Its New Monolith THX Subwoofer Series
(Monoprice) The new Monolith THX Ultra Subwoofer(September 1, 2017) CEDIA is a show that’s loaded with cutting-edge stereo and home theater tech, and every year one or two companies shock the system with a few products intended to disrupt the status quo. Last year, Monoprice hit the show floor with its impressive Monolith Air Motion Cinema Series Speakers. This year, the company has a variety of tricks up its sleeve, including three new subwoofer models submitted for THX certification. Monoprice says it hopes to receive final approval from THX within a few short weeks.
Priced from $500 to $1300, all three models sport configurable-ported HDF cabinet designs with horizontal and vertical internal bracing and onboard DSP control. Headlining the group is a 128-pound beast that’s awaiting THX Ultra Certification for use in home theaters as large as 3,000 cubic feet. The Monolith 15” THX Ultra Subwoofer features a 1000-Watt Claridy amp and a 15-inch bi-layer pulp/glassfiber cone. Because it has three ports, the sub can be run in one of three modes, with performance down to 14 Hz in a two-port configuration.
The Monolith 12” THX Select Subwoofer ($800) features a 12-inch driver paired with a 500-Watt Claridy amp. It weighs slightly less than the Monolith 15” (103-pounds) and features dual forward facing ports. Monoprice says the Monolith 12” is capable of hitting down to an impressive 18Hz.
The smallest offering (Monolith 10” THX Select Subwoofer) carries a 10-inch driver and a 500-Watt amp. This sub, along with the Monolith 12”, is under review for THX Select status (meaning certification for rooms up to 2,000 cubic feet). At 70-pounds, the Monolith 10” is much more manageable than its big brothers, and its enclosure (18.8” x 14.9” x 21.3”) is almost half as big as the Monolith 15”.
(Monoprice) The Monolith 10" and 12" THX Select Subwoofers
Monoprice says that all three subwoofers will begin shipping this fall.
The company is also beefing up other areas of its Monolith line with Planar over-ear ($199) and in-ear ($149) headphones, several THX Headphone Amp and DAC models with onboard Dirac technology ($229-$329), a Pure Tube Stereo Amplifier with Bluetooth ($329), a new line of in-wall speakers with ribbon tweeters ($119-$189), and a pull-down full-motion TV wall mount ($199). AV NIRVANA will have more details about these products during its coverage of CEDIA 2017.
Monolith THX Subwoofer Specifications
Monolith 10" THX Select Subwoofer
Woofer: 10", 60mm v.c, t-pole,bi-layer pulp/glassfiber cone, NBR surround
Enclosure: sealed/vented, HDF cabinet, horizontal and vertical bracing
Finish: black ash PVC
Amp: Claridy DSP500 - class D 500Wrms with DSP control
Harmonic Distortion (2nd & 3rd Harmonics): <1.0% 20-100Hz (90dB@1m)
Frequency Response: (-6db): Extended EQ Sealed: 28 - 200Hz, Vented: 18-200Hz; THX EQ Sealed: 31-200Hz, Vented: 20-200Hz
Variable Level Control: +15/-20dB
REF Level (100mV @ 40Hz): 89dB @ 1m
Crossover: inline/bypass, variable 40-160Hz
Variable Phase: 0-180o
Inputs: RCA(2), XLR
Outputs:(direct pass thru) XLR
Signal turn on: selectable always on / auto
Auto Turn Off: 30min
Dimensions: 480 x 380 x 500mm (543 w/grille)
Net Weight: 32.9 kg
Gross Weight: 42.6 kg
Monolith 12" THX Select Subwoofer
Woofer: 12", 60mm v.c, t-pole, dual shorting rings, bi-layer pulp/glassfiber cone, NBR surround
Frequency Response: (-6db): Extended EQ Sealed: 26 - 200Hz, Vented 1 port: 19-200Hz, Vented 2 port: 18-200Hz; THX EQ Sealed: 29-200Hz, Vented 1 port: 23-200Hz, Vented 2 port: 20-200Hz
Inputs: RCA(2), XLR
Dimensions: 580 x 425 x 600mm (643 w/grille)
Net Weight: 44.7 kg
Gross Weight: 57.0 kg
Monolith 15" THX Select Subwoofer
Woofer: 15", 60mm v.c, t-pole, dual shorting rings, bi-layer pulp/glassfiber cone, NBR surround
Amp: Claridy DSP1000 - 1000Wrms with DSP control
Frequency Response: (-6db): Extended EQ Sealed: 15 - 200Hz, Vented 2 port: 14-200Hz, Vented 3 port: 64-200Hz; THX EQ Sealed: 23-200Hz, Vented 2 port: 19-200Hz, Vented 3 port: 20-200Hz
Inputs: RCA(2), XLR
Outputs: (direct pass thru) XLR
Dimensions: 680 x 450 x 700mm (743 w/grille)
Net Weight: 58.3 kg
Gross Weight: 73.8 kg
