Multiple Inputs and SPL Logger
tannerupthegrove
Is it possible (with Pro license) to have the SPL Logger log up to 16 inputs simultaneously? I can see there are up to four SPL Meters possible at the same time, but I would like to use the SPL Logger for all inputs.
Similarly/alternatively, is there a way to log the individual RTAs of multiple inputs with a selectable interval?
Thanks, John!!
Success using the RTA via API! Can you confirm the RTA data is in Base64 strings? I am having a hard time decoding it ("magnitude").
I will also look at grabbing the four SPL Meters via API. Overall great additions with the API!
Feature Request for the Pro License: SPL Logger for multiple inputs :) and if using the application, changeable time intervals.
