NextLevel Acoustics Brings the "Color of Sound" to Samsung Frame TV and Soundbar Kits
(July 12, 2024) NextLevel Acoustics, a Boston-based architectural and design-oriented audio solution outfit, has launched a new service called "Color of Sound." It allows integrators to customize Samsung Frame TV frame kits and NextLevel Acoustics Fusion Frame soundbars with any Benjamin Moore paint color in matte or flat finish; a semi-gloss option will be available soon.
NextLevel says the service addresses a hole in the AV market for Samsung Frame TV bezel colors, which aren't available in palates beyond what it calls "standard color options."
“Color of Sound reimagines systems with more elegant and stylish audio integrations, transforming any media room from typical to spectacular using color,” explains Lee Weber, co-owner of NextLevel Acoustics. “There is no limitation on how creative integrators and designers can get.”
To participate, customers simply send NextLevel Acoustics a Samsung frame kit (white is preferred) in its original protective packaging and box. NextLevel takes control from there, using an internal two-stage process to paint the frame with a custom Benjamin Moore color. Once completed, it's repacked in its original protective packaging and shipped back.
For a finished aesthetic that looks and sounds great, NextLevel Acoustics' Fusion Frame soundbar line can be ordered in a color to match.
Designed for the Samsung Frame TV in style and form factor, Fusion Frame soundbars are the thinnest soundbars available. Using NextLevel’s proprietary Zero-Gap flush-mount system, the Fusion Frame soundbar has only 1.75 inches of exposed depth, while the Fusion Frame Slim soundbar, designed to match the Ultra Thin Samsung Frame TV, has only 1.25 inches. Both are available in a variety of designer grille fabrics and driver layout configurations.
Additional Reading:
