rochambeaux
- Jan 29, 2022
- 1
- Main Amp
- SMSL DA-9
- Other Amp
- Topping A30 Pro
- DAC
- SMSL SU-9
- Dali Spektor 2
- SVS SB-1000 Pro
Sorted through the info at MiniDSP relevant to the UMIK-1 mic I purchased and other "beginner" documents...
Is REW using this mic even possible/relevant for a dekstop system using a DAC, AMP and 2.1 speakers?
I keep running across the use of HDMI and how resulting outputs are used in AV systems, etc.
Is there a guide or tutorial geared towards the non-engineer novice like me?
