OS recommendation for REW
TheSound
Dear all,
we are currently setting up a measurement PC for REW and try to select the best OS (as Windows 10 does not work on the PC). While doing that, we would like to check out the usage of Linux.
Q1:
Can Linux be recommended according to your experiences?
Q2:
If yes, is there a certain Linux distribution that should be favourite? Ubuntu? Mint?
Q3:
Are there any traps on using Linux, and if yes which ones?
We are definetly going for adressing all speakers in the system, not only front L/R and subwoofer... Thanks a lot for supporting!
Best regards, Holger
