OTA GEAR INVEST ADVICE NEEDED
dreadknot
outlaw audio 976 7.2 balanced receviver
Crown xli 800 xls 1502
Crown xli 800 , Crown xli 800
crown xls 1502
nvidia shield (2017 model)
none
none
PL-89
PL-28II (for sale)
Klipsch RB-81 (sold)
Klipsch RB-81
none
none
none at the moment
none
Vizio M55-E0 (2017 model) upgrading to tcl 55in
none
none
none
none
i'm getting ready to ditch my hulu live tv service as we dont use that much an the vod library
we don't watch as much as as we do are other services
Disney plus , apple , paramount plus , hbo max , an amazon prime (all vi yearly option)
The combined vod library's cover all are desired content and we watch most evenly daily ,but we still want to live and if we could get the basic local ota we'd be happy happy happy!!! that's about 7 -13ch's
but we haven't used any Antenna gear in almost 20 years my dad still (wants) to record live football games when live
on nbc,cbs,abc,fox an certain nova and pbs shows
long ago i once considered getting a silicon dust unit but never did now we want to so what i want to know
is this will these three items cover my (wants) and if i tie this into my network what app do i need for
the ota gui & dvr control from the nvidia shield i'm ok with the Silicon Dust's service ($35/yr)
because its per year just like all the other services in keeping
_______________________________________________
gJhqf&content-id=amzn1.sym.3aaa24ab-eb65-4c9f-b64b-a539fc469ffc&pf_rd_p=3aaa24ab-eb65-4c9f-b64b-a539fc469ffc&pf_rd_r=
silicone+dust+hd&qid=1671673981&s=electronics&sprefix=silicone+dusthd%2Celectronics%2C169&sr=1-4&ufe=app_do%3Aamzn1.fos.
18ed3cb5-28d5-4975-8bc7-93deae8f9840
Is it a safe bet that this Antenna will get at least 13ch's or at min 7
without having to mount outside or on the roof ?
It really depends on the location of the broadcast towers in relation to where the antenna sits... Take a look at the location on one of these maps...
dreadknot
crown xls 1502
none
none
PL-89
PL-28II (for sale)
Klipsch RB-81
none
none
none at the moment
none
none
none
none
none
ok will do thanks
dreadknot
crown xls 1502
none
none
PL-89
PL-28II (for sale)
Klipsch RB-81
none
none
none at the moment
none
none
none
none
none
well i check out the DTV Coverage one an everything looked great but then i saw reads based on 30ft above ground level which would be 15ft above my roof ah! might as well put in a tree
but hey according to the map id get based on my lo'cal 20plus ch so if having the Antenna inside drop down to 13 to 7 then id be happy as a clam
Jack1949
Active Member
Loveland, Colorado
Yamaha RX-A3040
KING 5-CHerry Amp - Digital Amplifier Co.
Oppo BDP-103D
JTR 210RT
JTR 210RM
Ascend Acoustics Sierra Towers with RAAL
Polk Audio RT55i
Polk Audio RT35i
Dual JTR 118HT
miniDSP 2x4 HD
Samsung UN60H6350
Don't know if this is any help, or how far you are from the broadcasting stations, so maybe my info won't apply to you.
I live in a two story house that we bought in 1991 and I installed an attic antenna that same year. We live around 50 miles north of Denver and we've never had a reception problem getting the OTA Denver stations. I still have the same antenna hooked up to the TVs as a backup, just in case our DISH network service has a problem during bad weather. Local digital channels are just as clear as the DISH channels. The additional OTA digital channels have varying degrees of reception quality, but I never watch them so I don't care about those.
I also tried an EVOCA NextGen TV device this summer and my 30+ yr old antenna had no reception problems.
Good luck with your search.
dreadknot
crown xls 1502
none
none
PL-89
PL-28II (for sale)
Klipsch RB-81
none
none
none at the moment
none
none
none
none
none
