Problem calibrating
Jorge Villegas
Hello, I'm having some troubles with calibrating everything in order to do the measurements. I have a BIG KNOB STUDIO+ interface, and I'm using a Behringer ECM8000. When I try to calibrate Room EQ prompts me with an error of not receiving any data from the interface. Anyone out there has done this with this interface? Thanks!
Wayne A. Pflughaupt
Corpus Christi, TX
Roku Express
Canton Karat 920
Canton Karat 920
Canton Plus D
Hsu ULS-15 MKII
Stock Yamaha Remote
Make sure the interface is set as the “default recording device” in the computer’s sound controls. And if the GIB’s monitor is set for “off” or “computer.”
Jorge Villegas
I'm using a MacBook Pro and I don't see any option to make my interface the "default recording device" (although it is selected as OUT & IN). I think the problem comes where I have to select USB on my interface as a source in order to measure the room using the speakers and also select another source for the microphone.
Which REW version? How do you have the Soundcard Preferences set up in REW? Maybe post a screenshot of those. Make sure the interface is plugged in and set to the configuration you want to use it in before starting REW. There is a button "Generate debug file" on the Soundcard Preferences which may have relevant information.
