Problems with REW_linux_no_jre_5_20_14ea17.sh on the Raspberry Pi 4
Italy
I tried the latest versions of REW and when I measure the impedance the program crashes and I have to close it.
The error also occurs when I carry out the impedance calibration.
I attach the log files.
A greeting. Thank you
In the REW_linux_no_jre_5_20_14ea17.sh version the impedance measurement works correctly.
Thanks John for the quick fix. I wanted to tell you that REW continues to work very well on the Raspberry Pi 4.
Thanks again, greetings from Italy.
This is encouraging. Which os are you running?
At the moment my solution provides the S.O. Raspberry OS 32bit version, with the 64bit version I have some problems with waterfall graphs.
A greeting
