I would like to approximate an anechoic speaker measurement from 200hz to 20khz in an 11'x15' room. To do this I assume I would need to do gated measurements. Within REW, I believe gating is controlled via the IR panel which I have never used. Could someone explain what a good set of values for this panel would be for the measurement & environment I have defined.
Also if you could provide a brief explanation why the values were chosen, and if I should be setting other parameters.
If this has already been explained elsewhere, please provide a link.
