STucker
- Nov 11, 2024
- 10
- Denon AVR x4400H
- Samsung UBD-K8500
- Streaming Equipment
- Roku Ultra
- Streaming Subscriptions
- Prime Video
- Ascend Acoustics CBM-170 SE
- Center Channel Speaker
- Ascend Acoustics CMT-340c
- Surround Speakers
- Ascend Acoustics HTM-200 SE
- Front Height Speakers
- Definitive Technology 800
- Rear Height Speakers
- Dual Rythmik Audio FVX15
- Video Display Device
- 65 inch Vizio LCD TV
- Other Equipment
- mini-DSP 2x4 HD
Hello - I am working to measure my two FVX15 subs using REW. Per recommendations from YT videos and other sources, I set the crossover on my Denon X-4400H to 250HZ for all speakers. With this crossover setting I didn't expect to hear any output from the left and right mains when I set the REW Generator to Sub Cal (30 to 80 HZ), but the main speakers had sound output. I disconnected one of the speaker wires to eliminate sound from the mains when doing the sub measurements.
Anyone have an idea why the main speakers are still outputing sound with a 250HZ crossover? Secondly, would this cause an issue with the sub measurements? For example, if the output to the mains should be going to the sub, am I loosing SPL on the sub when doing the REW measurement?
I have a related question. I used the REW SPL Meter, my Umik-1 and the Denon speaker test tone to measure the output of my 5 bedlayer and 4 Atmos speakers so they all measured 75DB at the MLP. When I set REW to measure the sub SPL, the volume on the left main, as referenced above, was far higher than the 75DB I had just calibrated. Any insights on what is causing this problem?
Steve T
Steve T
