REW vs ISO3382-1 standard etc.
burncpt
Gato Audio DIA-250S NPM
Tangent Ampster BTII
Gato Audio DIA250S NPM
Gato Audio NPM module
Acoustic Energy Reference 1
REL T-Zero Mk III
Hi all, and thanks for your consideration! I'm pretty green with REW itself but hoping to use it in a semi-professional manner for an acoustics project, for RT measurements using the ESS method. As part of the project I will need to be able to assess the performance of the measurement system against the standards set out in e.g. ISO 3382-1 and ISO 16283-1. I don't have access to laboratory environments for measurements in the free-field, for example, and obviously my microphone/soundcard/speakers are a somewhat unique setup. Instead, does anyone know of any studies that compare REW and a typical microphone/PC setup against professional type-certified equipment, for a baseline?
burncpt
REL T-Zero Mk III
Thank you very much John! Apologies for sending email direct as well, just trying all avenues. I will check it out.
