REW won't receive audio from core audio interface on Monterey 12.6
Mick Guzauski
Hi,
I'm having a problem with REW and other apps on os 12.6 (12.5 worked fine)
Computer is a Mac studio.
With either Dante or a Thunderbolt audio interface, I can't get audio to REW and a few other apps.
Apps will still output audio to the interfaces.
Input to Pro Tools, Logic and Quicktime still work.
Maybe because of Apple security updates ?
Any Ideas ?
Thanks, Mick
It shouldn't be a security issue, since REW is a signed, notarised app with mic permissions as part of the signature. Perhaps Apple have changed something though. Which other apps have the same problem?
Running MacOS Monterey 12.6 here... On a MacBook Pro (Retina, 13-inch, Early 2015)... And REW 5.20.14... Just tried with a UMM6... Everything works as expected...
Might have a look at the Audio MIDI setup control panel... Are you using something like Soundflower or BlackHole to route I/O? Also check System Preferences, Security & Privacy, Privacy, Microphone - Make sure REW is checked...
