room eq wizard settings help
hardcore_gamer99
DENON X4800H
PANASONIC 4K PLAYER UB820EGK
DALI OPTICON 2 MK2
SVS PB 2000 PRO
WSONY OLED 65A80L
Cables
SVS
Whole House System
NOT ACOUSTICALLY TREATED BEDROOM
I am using this on pc and hdmi from my nvidia to denon avr. I use flexiso. I want to know how do i run left + right speakers fronts simultaneously in rew. And also is it possible to run L+R+SUBWOOFER in 1 measurement if so how? What to select in output
When using ASIO there is an option to select a second output, which can be any channel. If the fronts are not full range then anything sent to either front speaker will have the low end redirected to the sub.
crossover set to 80hz sir
