(April 26, 2021) Sonarworks has announced a new industry partnership with Drop, integrating its SoundID personalized audio technology into the Drop + THX Panda Wireless Headphones.
The Drop + THX Panda Wireless Headphones are a closed-back planar magnetic design capable of delivering playback from 10Hz to 50kHz (26ohms, sensitivity 100dB), powered by a THX-AA-O Amplifier (-130 dB THD, 2.6uV A-wt noise, 10mW). Wireless connectivity features Bluetooth 5.0, which offers an effective range of 30-feet, and battery life can last over 30 hours. In addition, a robust IPX 6 rating means the headphones can resist a high-pressure water stream from any angle.
SoundID brings Sonarworks' Advanced Parametric EQ functionality to the table, allowing users to create a personalized sound profile that customizes how music sounds. The entire SoundID experience begins with an app-based test that identifies and saves listening preferences, while also uploading them to the Drop + THX Panda Wireless Headphones. Once onboard, DSP cores apply EQ to any source. Thanks to smart algorithms and machine learning, SoundID is able to evolve based on listening habits – owners can always adjust or reset output settings.
You can purchase The Drop + THX Panda Wireless Headphones with SoundID ($399) by visiting drop.com.
