Sound Absorption Effective?
Mike Schramm
Bright Side Crew
Minooka, Illinois
Onkyo TX-RZ840
Emotiva BasX A7
Panasonic DP-UB820
Apple 4K
Netflix, Hulu, Apple Music, Amazon Prime
SVS Ultra Bookshelves
SVS Ultra Center
SVS Prime Satellites
SVS PB-2000 Pro (x2)
miniDSP 2x4 HD
Sony XR-77A80J
Logitech Harmony One
Hi all. Yesterday I hung some sound absorption panels at the first reflection point and am curious how effective they are. What test on REW should I run to find the appropriate measurements and what am I looking for in the measurements? Thanks in advance!
dotnet
Calculate the difference between the travel times of direct sound from your speaker and sound via the first reflection point (difference in path length divided by 343m/s). Run a single speaker sweep with time reference. The ETC graph in the Impulse tab will show a spike at or near the calculated time (it’ll likely stick out higher than about -20dB). With the absorption panels in place that spike should have a lower amplitude.
Mike Schramm
Bright Side Crew
Minooka, Illinois
Onkyo TX-RZ840
Emotiva BasX A7
Panasonic DP-UB820
Apple 4K
SVS Ultra Center
miniDSP 2x4 HD
Sony XR-77A80J
Thank you dotnet!
