Steinberg UR22 MkII Calibration Problem
tbingel
I am new to REW albeit being an audio professional.
I was trying to calibrate the interface to squeeze the last drop of precision from UR22 MkII.
The hookup is like this:
Output: Line Output 1
Input: Input 1
Using ASIO w/24-192 and Standard latency
Cabling: TRS from output to XLR input with a good quality Oyaide Balanced TRS-XLR cable.
Software config is as in the attached images
Problem: I cannot get the loopback signal to level with output. It just jumps to beyond 0 dB and returns the excessive signal error message.
What am I doing wrong?
Thank you.
Make sure the mix knob is turned all the way around to DAW, otherwise the monitoring creates a feedback loop.
