Stepped level plot shifts when changing between Generator and Input
BVa
Hello, question about scaling of distortion graphs in last Beta version. The same stepped measurement in card loopback, displayed distortion card, two pictures , generator level vs. input level. Input level is shifted down 3dB, but this apears only with dBFS (and SPL) units. Is it correct? Or generator is displayed in peak level and input in rms?
Same problem. Another measuring. In menu activated "Full scale sine rms is 0 dBFS"
In five units there is input = output, only SPL and dBFS are different (-3dB). See results in table below.
Another example.
In Y axe there is -20dBFS to -10 dBFS (fundamental)
In X axe there is -23dBFS to -13 dBFS
John, I think I found it.. Setting "Full scale sine rms is 0 dBFS" in preferences seem to work inversely. If it is dissabled, than graphs are correct, generator/input are identical. Problem solved.. OS is old Win XP..
It should work regardless of that setting, though the generator level will reflect however it was set when the measurement was made. I can send a link to a test build to fix it, do you need 32-bit or 64-bit?
Hi John, could you please send the 32-bit link to me as well? Thanks in advance.
Problem is solved. Thank you. But there is still one little thing to solve. Reading from the cursor is shifted 6 dB.
